Hello everyone.
Somewhat of a newbie here but have been lurking for a while. Based on what I have read seems that the Z12 is the way to go. I have ordered and received two cams from Andy and am now ready to mount them somewhere? My house does not have the best angles to the street and does have a good amount of trees in the front. I have the added difficulty of having the house somewhat setback from the street increasing the angles a bit. I know that some of you have had good success in capturing the tags from a fair distance away, however not sure what angles you are faced with or what is an acceptable angle. Practically speaking, other than less than 30 degrees what is considered acceptable?
These are the possible locations for the cams, including some of the trees I have to try and shoot through. I do need to capture both directions but could mix and match locations if needed. Appreciate any comments or advise.
