Hello folks, I’m trying to solve an issue I’ve been stuck on for about a week. I have a Wisenet SPC-7000 controller connected directly to a Wisenet HRX-1621 DVR through the RS-485 TX+/TX- terminals. The PTZ side works fine: I can select a camera (e.g., “12 + CAM”) and the joystick moves it with no problem. But none of the DVR control functions respond — no fullscreen/single view, no layout switching (16-tile to 1-tile), no tile selection, and basically none of the other buttons do anything besides the number keys and CAM. What I want is for the SPC-7000 to control the DVR directly, so when I select a PTZ camera I can quickly jump full screen ↔ split view and move to the next aisle camera fast (speed and ease of use are the priority for loss prevention). Right now I’m forced to use a mouse to double-click in/out of fullscreen, and it’s too slow when things actually happen. One extra detail: the PTZ only responds when the system is set to 2400 baud (not sure if that matters). I also tried Wisenet SSM, but that only helps on the PC side and I’m getting delay/RAM issues — ideally I want to control the DVR directly for the best resolution and fastest response. Has anyone run into this with an SPC-7000 + HRX-1621, or know the correct configuration to get DVR layout/fullscreen control working? Let me know if you need any other info!! Thanks a bunch!
