Help me pick up first camera system
EUcLad
Mar 1, 2021
1
Mainland EU
Hey all,
So I bought a townhouse (or whatever you call the houses built in a row), so obviously now I'm thinking about how to secure it. I live in a relatively safe and semi-rural area, so I could probably get away without the security system (lot of people around don't have anything, some have subs with security companies, which gives them one indoor camera and a nice sticker to put on the front door), I still want to offer my family so increased sense of protection. We also have a small backyard (under 40 sqm or 430 sqft), and, since we have kids, I'd love to be able to have a live feed over what they're doing just in case.
I can probably get away with two to four cameras, with one to two on each side of the house, covering both the small space of the land and the entries to my house (windows & doors). I don't have a garage (nor car), so I don't have to worry about it, and there's nothing valuable in a small shed connected to the house. Ideally, I'm looking for PoE cameras, hopefully somewhere around the $100 budget for each.
I've seen a lot of Dahuas and Hikvisions recommended, along with a seller, but there's the catch - I'm in Europe, not US. From my quick Googling around, the prices are CRAZY. IPC-HDW5231R-ZE, for example, costs 330+$ here, while I've seen it for around 170$ on Amazon.com. Therefore, is there any EU supplier that you'd recommend that has a.) good cameras & b.) prices that aren't crazy compared to US? I'd rather not ship the things from HK/CN if I don't need to, as the taxes/duties would probably drive the price up by 30+%.
If you are interested in International Dahua cameras, a forum member sells dahua (and some Hikvision) and ships world wide. You can read some of the members recommendations on his service. He also provides cameras to other forum member for evaluation and reviews.
You can email him for a quote, or purchase from his Aliexpress store or his Amazon store. The cameras are fully upgradable, he posts upgrade software when available.
I recommend emailing andy for a quote. His shipping to the EU is excellent.
Andy
@EMPIRETECANDY
[email protected]
Andy's ipcamtalk vendor forum: EmpireTech Andy
Andy's AliExpress store: Empire Technology Co., Ltd - Amazing prodcuts with exclusive discounts on AliExpress
Andy's Amazon store: Amazon.com
Reactions: looney2ns
:welcome:
A lot of info follows. Take you time..
We have a large number of members for the EU.
Start with one good quality variable focus camera. This will be used yo test your camera lens selection and your camera placement.
My standard welcome to the forum message.
Read Study Plan before spending money
Cameras are for surveillance to get information for after the fact.
Please read the IP Cam Talk Cliff Notes and other items in the IP Cam Talk Wiki. (read on a real computer, not a phone). The wiki is in the blue bar at the top of the page.
Read How to Secure Your Network (Don't Get Hacked!) in the wiki also.
Quick start
1) If you do not have a wired monitored alarm system, get that first
2) Use Dahua starlight cameras or Hikvision darkfighter cameras if you need good low light cameras.
3) Start with a good variable focus camera, so you test for the correct lens,lighting, camera placement.
4) use a VPN to access home network (openVPN)
5) Do not use wifi cameras.
6) Do not use cloud storage
7) Do Not use uPNP, P2P, QR, do not open ports,
8) More megapixel is not necessarily better.
9) Avoid chinese hacked cameras (most ebay, amazon, aliexpress cameras(not all, but most))
10) Do not use reolink, ring, nest, Arlo, Vivint cameras (they are junk), no cloud cameras
11) If possible use a turret camera , bullet collect spiders, dome collect dirt and reflect light (IR)
12) Use only solid copper, AWG 23 or 24 ethernet wire. , no CCA (Copper Clad Aluminum)
13) use a test mount to verify the camera mount location. My test rig: rev.2
14) (Looney2ns)If you want to be able to ID faces, don't mount cams higher than 7ft. You want to know who did it, not just what happened.
15) Use a router that has openVPN built in (Most ASUS, Some NetGear....)
16) camera placement use the calculator... IPVM Camera Calculator V3
17) POE list PoE Switch Suggestion List
18) Camera Sensor size, bigger is general better Sensor Size Chart
19) Camera lens size, a bigger number give more range but less field of view. Which Security Camera Lens Size Should I Buy?
20) verify your camera placement, have a friend wearing a hoodie, ball cap and sunglasses looking down approach the house, can you identify them at night ?
21) DO NOT UPGRADE your NVR or camera unless you absolutely have a problem that needs to be fixed and known what you are doing, if you do you will turn it into a brick !!
Cameras to look at
IPC-T5442TM-AS-LED . Review IPC-T5442TM-AS-LED (Full Color, Starlight+) - 4MP starlight
.................... Dahua IPC-T5442TM-AS-LED review
IPC-T5442TM-AS ..... Review-OEM 4mp AI Cam IPC-T5442TM-AS Starlight+ - 4MP starlight+
IPC-HDW5442t-ZE .... Dahua IPC-HDW5442T-ZE 4MP Varifocal Turret - Night Perfomance testing -- variable focus 2.7 mm-12mm 4 MP Starlight
IPC-B5442E-ZE ...... Review - OEM IPC-B5442E-ZE 4MP AI Varifocal Bullet Camera With Starlight+ -- variable 2.7mm-12mm bullet
IPC-B5442E-Z4E .... bullet 8mm-32mm variable focus zoom 4MP
IPC-HFW7442H-Z ..... Review - Dahua IPC-HFW7442H-Z 4MP Ultra AI Varifocal Bullet Camera -- 4 MP variable focus AI
IPC-T2347G-LU ...... Review of the Hikvision OEM model IPC-T2347G-LU 'ColorVu' IP CCTV camera. (DS-2CD2347G1-LU)
IPC-HDW2231R-ZS .... Review-Dahua IPC-HDW2231RP-ZS Starlight Camera-Varifocal
IPC-HDW2231T-ZS-S2 . Review-OEM IPC-T2231T-ZS Ver 2, 2mp Varifocal Starlight Camera
IPC-HDW5231R-ZE .... Review-Dahua Starlight IPC-HDW5231R-ZE 800 meter capable ePOE
IPC-HFW4239T-ASE ... IPC-HFW4239T-ASE
IPCT-HDW5431RE-I ... Review - IP Cam Talk 4 MP IR Fixed Turret Network Camera
IPC-T5241H-AS-PV ... Review-OEM IPC-T5241H-AS-PV 2mp AI active deterrence cam
IPC-T3241-ZAS ...... Review-OEM IPC-T3241-ZAS 2mp AI Lite series Varifocal -- 2mp AI Lite series Varifocal
IPC-HFW2831T-ZS ... Review-Dahua IPC-HFW2831T-ZS 8MP WDR IR Bullet Network Camera -- 8MP Bullet 1/1.8” sensor variable focus.
DS-2CD2325FWD-I
N22AL12 ............ New Dahua N22AL12 Budget Cam w/Starlight -- low cost entry
IPC-T2347G-LU....... Review-Loryta OEM 4MP IPC-T2347G-LU ColorVu Fixed Turret Network 4mm lens & Junction Box -- 4MP ColorVu
.................... Review of the Hikvision OEM model IPC-T2347G-LU 'ColorVu' IP CCTV camera.
Other dahua 4MP starlight
My preferred indoor cameras
DS-2CD2442FWD-IW
IPC-K35A IPC-K42A
If interested in Blue Iris and other setup items see the following post
Read,study,plan before spending money ..... plan plan plan
Doing it right the first time will save you money.
Test do not guess
