wittaj IPCT Contributor Apr 28, 2019 35,303 67,416 USA Apr 2, 2023 #41 Ri22o said: On a side note, my IVS tripwire for the spotter is triggering in both directions even though it is only set to B>A Click to expand... Make sure that MD or SMD isn't also turned on in the spotter cam.
Ri22o Known around here Jul 30, 2020 2,411 4,728 Indiana Apr 2, 2023 #42 wittaj said: Make sure that MD or SMD isn't also turned on in the spotter cam. Click to expand... Both off. When looking at the event captures, it is clearly an IVS trigger but it doesn't matter which way the person is going.
wittaj IPCT Contributor Apr 28, 2019 35,303 67,416 USA Apr 2, 2023 #43 I guess try to delete and re-add Post some screenshots - there might be another check box or something in this new GUI that is messing it up?
Ri22o Known around here Jul 30, 2020 2,411 4,728 Indiana Apr 2, 2023 #44 Spotter is on the old GUI. I will do my best with screenshots as I navigate around it, I am sure I will miss something that could be important. These are really the only things I see that can be relevant with the PTZ.
wittaj IPCT Contributor Apr 28, 2019 35,303 67,416 USA Apr 2, 2023 #45 Oh OK I was thinking it was the new GUI for IVS. I meant the screenshot from the IVS rules Did you do a zig zag? If so that is why as the zig zag makes it go both directions. To do one direction it can only be one straight line, so then you need several IVS rules if you want a few points that could trigger. Reactions: bigredfish
Ri22o Known around here Jul 30, 2020 2,411 4,728 Indiana Apr 2, 2023 #46 wittaj said: Oh OK I was thinking it was the new GUI for IVS. I meant the screenshot from the IVS rules Did you do a zig zag? If so that is why as the zig zag makes it go both directions. To do one direction it can only be one straight line, so then you need several IVS rules if you want a few points that could trigger. Click to expand... Ok, that's the issue then. I did a zigzag to cover the area as much as possible. I did notice it was very confusing on which way was A>B and B>A because it always seemed to be the same. Reactions: bigredfish
