I was inspired by this thread and want to replace my baby monitor with an IP cam. Obviously I can just connect the cam to my home network and I'm off to the races...
Here's my problem..
I ALSO need to be able to have my setup be able to come with me when my family travels. For example, I need to be able to take everything and plug it in at my in-law's house and have the system up and going immediately. I have decided on the Hikvision 2432 and figure I need a travel router in the mix. This is where the plan gets fuzzy. I'm assuming that when I'm on the road I can plug in the cam and travel router and it will broadcast on a preset IP address. That's fine and good -- but when I'm at home I want the system to be part of my home setup (BlueIris) so that I can view the cam with my other cams. For this to work I'm assuming I need the travel router to be part of my home network. So what I think I need is for the travel router to connect to my home network thus adding the cam to my home network .. and on the road it simply broadcasts it's wifi (allowing access to the cam)... and in both scenarios the webcam will have the same IP. Is this possible?
Thanks!
Here's my problem..
Thanks!
