Help me choose between these cams?
Spizz
Jun 27, 2018
31
9
Australia
Need a little help deciding. — Dahua vs Hikvision + one 180° cam?
• All rounder + low light performance?
Dahua IPC-HDW5859H-ZE-PV-PRO or Hikvision DS-2CD2387G3-LIS2UY/SL
and one 180° cam:
Hikvision DS-2CD2387G2P-LSU/SL or Dahua IPC-PDW3849-A180-AS-PV
and one 180° cam:
you comparing higher 5-line Dahua AI-ISP cam with lower 2-line HIK Vision AI-ISP cam...
of course 5859-PRO is better here..
more comparable will be Dahua 3449-PRO for that HIK vision model..
you should more select in what ecosystem (NVR, mobile app, web panel) you want to live: Dahua or HIK..
all actual 180 cams are bad... we wait for next generation...
Reactions: Spizz and looney2ns
5 series it is! :)
Yeh - I haven't been able to find one that sold me.
I may try the hikvision one as it seems to have better sensor and aperture over the dahua one.
I've only ever used dahua products with blueiris.
