Hi All,
I recently purchased some Hikvision CB140PT junction boxes, and intend to have my CAT6 line coming out of the side gland. I noticed that even after tightening the gland, it leaves far too much space for one cable. I did look into this thread that had the same issue:
ipcamtalk.com
I already purchased some Duct Seal, but was unsure whether to use that alone to seal it, since the cable would be hanging to some extent. I was afraid the wind/weather would eventually compromise the seal. Also didn't want to rely on gravity/drip loop alone, since I hear moisture from change in temperature alone could cause issues. That being said, I did notice the camera's own weather proof connector had a plastic (grommet?) piece that could be slipped onto the cable. I have attached an image as reference (see arrow). The addition of this piece seemed to allow for a good seal on the gland after tightening the nut. Since I will need to use that piece on the connection to the camera, does anyone happen to know where I could purchase a set of these without having to buy an entire set of connectors as well? Backup plan was to follow one of the other suggestions of applying electrical or amalgamating tape to fit, but that seems like it would be a pain if the cable had to be changed/re-terminated down the road.
Thanks in advance.
Waterproof cat5 entry into junction box
I bought a few hikvision CB140PT junction boxes to install my turrets. The boxes have a nut on the side that seems like it is supposed to be waterproof when tightening down, but the rubber grommet is still too big for the cat5 cable. Is there a better junction box to use in this application...
Thanks in advance.
