Help - Installation of camera near garage
Jul 23, 2018
9
3
USA
We are building a new house and we had the contractor run cable to the top right corner of the garage. I figured I would just mount the camera under the soffit on the corner. I forgot that they added a decorative wood trim which looks to block the view if I mount the camera on the corner. The camera I'm looking to purchase PC-T54IR-ZE-S3
Any recommendations or mounts I should use to mount the camera?
Thanks
Depending on which camera is to be pointed in which direction, the PFB-203W might work well. Other than trying to not mount above 8 ft., one also has to consider proximity to surfaces (gutters, trim, soffit boards, etc.) which can cause IR bounce-back at night.
Reactions: looney2ns
