Hi everyone,
I'm having an issue with my Hikvision DS-KH9510 video monitor. After some intermittent power outages at my house, the monitor now boots into the Android Recovery screen. I want to select the "wipe data/factory reset" option to try and restore the system to factory settings, but I'm facing a few problems:
![r/Hikvision - [Help] Hikvision DS-KH9510 Stuck in Android Recovery - No Physical Button to Select Options r/Hikvision - [Help] Hikvision DS-KH9510 Stuck in Android Recovery - No Physical Button to Select Options](https://preview.redd.it/help-hikvision-ds-kh9510-stuck-in-android-recovery-no-v0-je6llxppcoid1.jpg?width=4000&format=pjpg&auto=webp&s=6f92bc36c673932fbc027267ba24f33bae895320)
![r/Hikvision - [Help] Hikvision DS-KH9510 Stuck in Android Recovery - No Physical Button to Select Options r/Hikvision - [Help] Hikvision DS-KH9510 Stuck in Android Recovery - No Physical Button to Select Options](https://preview.redd.it/help-hikvision-ds-kh9510-stuck-in-android-recovery-no-v0-pu0twq4ldoid1.jpg?width=4000&format=pjpg&auto=webp&s=e677e91daa2b531799664a45123bef87d038a88e)
2. The touch screen is disabled, so I can't select any options directly.
3. I’ve tried flashing the system via CMD using ADB. The device shows up when I run adb devices, but I couldn't get it to recognize the memory card that has the "digicap.dav" ROM file I downloaded from Hikvision's website.
I have a basic understanding of ADB and feel comfortable with some commands, but I'm not an expert in more advanced procedures. I'm looking for a simple way to get my monitor working again, either by finding a physical button I may have overlooked or through USB debugging commands.
Has anyone experienced this or have any suggestions on how to fix it?
Thanks in advance for the help!
- I can't find any physical button on the monitor to select options from the recovery menu. There’s only a black button (like in the attached picture), but it doesn't seem to do anything.
