HELP HIKVISION DS-2CD2T42WD-I5 Exir 4mm vs. DS-2CD2T23G0-i5 4mm
pokibeans
Mar 21, 2018
1
Hey guys, need desperately your help!
The local CCTV provider installed 2 bullet cams. Agreed was the model DS-2CD2T42WD-I5 Exir 4mm. However I recognized 2 days later that they actually installed the model DS-2CD2T23G0-i5 4mm.
Now the question is if the model they installed is same quality or better or worse. I already googled the crap out of it, but I cannot find any proper info which is the newer version, technology etc. I can see that the offered one has 4mp and the installed one 2mp and a different IR but appart from that I dont know what would be the better model. Obviously the result would be either I complain and request a change to the offered model, or keep the installed version.
Thanks a lot for your help!!!
DS-2CD2T42WD-I5 has a smaller sensor. not good at night, 4mp. other one has a bigger sensor and 2mp better at night. daytime the DS-2CD2T42WD-I5 has better image.
