- Oct 8, 2015
- 1
- 0
Hi there!
I have been reading a lot on this forum and is amazed by the knowledge some people have here.
I have a problem, I have this Anran IP camera: http://www.anranhtshop.com/views.asp?hw_id=1132 (IPC model with HI3516C SoC) and was doing a firmware update per Anrans instructions via e-mail the other day. (This firmware https://pan.sohu.net/f/MTY4MDQsaGR1Ym0.htm (IPC53H20L V4.0.R11.00001532.1)) and I was upgrading from V4.02.R11.00001532.10010 with build date 2014-02-26.
The update bricked the camera and it doesn´t get an IP-address anymore.
I have been able to connect to the camera using a serial cable and connecting to U-boot works fine, but I can´t get further. I have the .bin file for the firmware for both the advised firmware by Anran and an older .bin-file with the same build date as the one that was on the camera from the beginning.
Is it possible to rebuild this to the required update.img-file to flash via serial and TFTP-server? Or better, does anyone know where I can get the file? Anran doesn´t answer me anymore, convinient huh?
If I extract the .img-files from the .bin and rename them to update.img I can upload them to the camera using the run up command and flash them one by one, but the camera still doesn´t work after that. Worth to mention is that I can only do this with the firmware with build date 2014-02-26. If I try with the newer firmware, I get messages from U-boot saying it doesn´t match with the memory or something like that.
One other thing, if I ping my router from U-boot, it actually shows up in the routers device list for a minute or so.
Everything is there, and I feel that it has to be possible to recover it in some way?
Please help me, I will be forever grateful!
(And please forgive my english, it´s not my native language)
