Hi Folks. This is my first post here driven by the frustration of not finding what I'm looking for, partly because I'm not quite sure what it is I should be looking for. I'm hoping some of you peeps can help guide this blind man in a sand storm.
Here's my conundrum...
I live at the end of a upward inclined cul-de-sac, about 70 feet from the street with no hedge and overall dimly lit. I'm looking for a single camera that can be fitted to the wall of my house (no eaves) and look down along garden with trees either side and onto the street. This isn't a serious security endeavor, I'm just interested in the technical side and watching capturing comings and goings. I am really not interested in hard-wiring anything other than for power and I think I can get a good wi-fi signal to where i need it. The biggest problem I'm having (probably needless to say) is with night vision. I'm open to using using floodlights if it would help, but lighting up the whole street is a bit ambitious. My requirement in bullets would be:
- Wi-fi
- Good night vision 100+ feet
- Not wide angle: <= 90 degrees would be fine
- Motion detection with zones
- Integration with Amazon Echo Show and Android
- Local storage (SD card)
- 1 or 2-way audio optional
