HI all. Have a look at my dodgy drawing. I've installed a bunch of cams with no issues. This one needs to be mounted on a side wall, but "see" around the corner. I have a matching mounting baseplate PFA130-E, however it will bring the base of the cam (circular plate) off the wall by only about 30mm, and I'd need maybe min 100mm to achieve the angle I need. I could knock something up to "extend" from the wall plate to the cam, but messy and would invite water (it's outside and quite exposed).
Any thoughts?
Cheers, Mat
Could I possibly use one of these?
So above wall mount, then attach the cam's round mounting plate (or add in the PFA130-E if needed to make it fit), and put a 90deg bend in the cam's adjustment so it points out flat (as per drawing, but with cam's mounting plate parallel to ground)? Does that make sense? Mat
Any thoughts?
Cheers, Mat
