Hi,
I got a cheap RTSP+ONVIF camera from Amazon and I am able to connect to the RTSP stream (video+audio) using VLC Player by using the following URL:
http://192.168.1.62:554/live/ch0 and then typing the username+pass as per the camera manual.
I am running VLC from the same PC that runs BI.
But when I try to connect from Blue Iris it won't connect.
This is the output of the Inspect:
Opening 192.168.1.62 port 80...
ONVIF GetSystemDateAndTime
1970-01-01T06:37:53.000Z
Requesting device information...
Manufacturer: oem
Model: xseries
FirmwareVersion: 00.30.01.0049
GetCapabilities...
Querying services
Has Imaging services: /onvif/device_service
Has media services: /onvif/device_service
Has RTP_RTSP_TCP, requesting profiles
first profile is Profile_token1
first source is VideoSource_token1
requesting URI for profile Profile_token1
RTSP URI: /live/ch0
Has Event services: /onvif/device_service
Has WSPullPointSupport
RelayOutputs: 1
InputConnectors: 0
Has Device IO services: /onvif/device_service
AudioOutputs: 1
Has PTZ service: /onvif/device_service
Done
If I accept the settings that BI detected as-is, it doesn't work and I get: "No Signal"
If I try to change the URL to rtsp:// and then 192.168.1.62:554 it keeps reverting the URL to :80 as soon as I tab out of the URL field, and looks like this (and same "No Signal"):
Any idea why VLC works and BI doesn't?
THANK YOU!!!
PP
Manufacturer: oem
Model: xseries
GetCapabilities...
Querying services
RTSP URI: /live/ch0
RelayOutputs: 1
InputConnectors: 0
AudioOutputs: 1
Done
THANK YOU!!!
PP
