Finally bit the bullet and bought a real camera from Andy and finally got time to mount it and get it going. It powers up (POE) and draws power and links with the switch. I can only assume for some reasons it failed to get DHCP lease and instead went to the default of 192.168.1.108.
How can I force it to do DHCP on the first boot so I can then get in and set a static IP? I cannot will/not install any apps I cannot connect the camera to a PC, It is already mounted and I don't have another POE switch i can use, etc. The cameras are all on a VLAN that is not 192.168.1 and I cannot easily move anything around to change that.
I just want to boot it up and configure it like any other device, it gets a DHCP address, you login and do whatever, done. I have 2 Amcrest ip8m-2493, one was converted long ago to dahua firmware, and I do not remember having to do some 192.168.1 hack to access the thing. Is this really the only way to set up a brand new camera? If so how can these things be deployed at scale with automation (what I do for work) if you have to do this kind of nonsense manually for each one?
I hope there is a realistic option or I will have to ship this back and be happy with my Reolink garbage, fortunately I bought it from Amazon so no hassle to dump it at Kohls and send it back.
Thanks for any help
Thanks for any help
