Please help!
my Blue Iris 4 was running smoothly, after added another camera "Foscam FI8602", I changed the souces from " foscam - FI86xx/98xx" under the drop list to "Generis RTSP HTTP tunneled" because the FI86xx/98xx is not working in B.I.4 but work at B.I.3, after that my BI4 crashed.
A message popped out after I try to restart the BI4, it said "Blue Iris VIdeo Security and WebCam Software has stopped working" "A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available." then I have to force close the program again.
After couple of tries, I can get to the interface, I saw a popup message said I can update B.I.4 to 4.3.3 then crash again with the same message above. it is the reason to cause my BI4 keep crashing?
Now I cannot get into the user interface, so I cannot delete the FI8610 camera as well to see if this is the reason to cause this issue.
Any expert can show some love and help me out please if you know what's going and how to fix it?
Thank you.
Peter
Thank you.
Peter
