Hi,
I was hoping for some guidance with setting up a Dahua POE switch (DH-PFS4218-16GT-240) with a Dahua POE NVR (DHI-NVR5432-16-I/L 32CH).
I currently have 16 IPC-HDWW3549HP-AS-PV Cameras plugged in to the NVR, it works fine and was pretty straight forward to setup.
The problems is I want to add an additional 4 cameras.
I have done some reading about setting up the IP manually, but I am confused on how to go about doing this as it hasn’t seemed to have worked.
It was initially setup as follows: Router ---> NVR —> Cameras
I have now plugged it in as follows: Router —> Switch —> NVR LAN Port —> Cameras
—> Cameras
For reference, the gateway/router is 192.168.50.1 and the NVR is on 192.168.50.155
The working cameras for some reason have auto setup with an IP address of 10.1.1.xx
This seems different from other setups I have read about….
I would appreciate some advice on how to setup the additional cameras on the switch.
Happy to provide further information or screenshots if needed.
Thanks in advance!
—> Cameras
Thanks in advance!
