I plan to ultimately have a mixed environment of some POE cameras connected directly to the NVR, but I will also want a camera or two connected to my local network, but powered from a conventional 12v wall transformer. So I wonder about IP addresses.
I have given my NVR and address on my current network. 192.168.20.2. Default gateway is 192.168.20.1, and my router is the DHCP server starting at 192.168.20.5
I still have the default ip address on the two IPC_5231 cameras I have connected at this point. They are on 10.1.1.65 and 66.
Should I continue with separate octects? Can they function just fine in a "mixed" environment? Or should I change everything to 192.168.20.???
My plan is to setup a wireless bridge to another building and connect a camera or two there. I am hoping to use some old hardware I already have, and was not planning on a POE switch. Thus the use of the 12v power supply for each camera. Keep in mind that the bridge will be back to my 192.168.20.1 router.
Can a 10.1.1.? camera communicate back to the NVR in that enviroment? I have my doubts because I cannot go to the camera web interface by typing in the address, like I do for the NVR.
I have another question regarding the 12vdc power supply for the camera. The sticker says 12vdc 1A. That is straight forward. However, what is the polarity of the plug? Positive in the center?
Thanks
Thanks
