- Jul 1, 2015
- 99
- 7
Hi fellows,
I have a few newbie questions regarding IP cams, and specifically HikVision cams.
Planning to put external cameras on my single storey house for monitoring and recording.
I have been looking at Samsung but they were quite expensive. HikVision seems to be a very popular brand hence more peer support available.
Looked on HV website and it mentions 2-line and 4-line cameras...
Do the 2-line cameras have model numbers starting with 2xxx and 4-line start model numbers with 4xxx ?
What is the difference between a 2-line and 4-line cam ?
Also, what is the difference between these two cameras, one selling for $84, other for $95 !
Model numbers are 2332 and 3332 ....
http://www.aliexpress.com/item/Whol...32-I-POE-3MP-dome-camera-mini/1456148771.html
http://www.aliexpress.com/item/HIkv...mera-DS-2CD3332-I-support-POE/1391903517.html
What do the HV model numbers mean ?
The 2332 is a pretty popular model, but it isn't a vandal dome. It doesn't even have any dome ? So how would it be protected from the elements if it is an outdoor camera ?
Is EXIR better than IR ?
Does the EXIR refer to the separate IR illuminator as shown in this camera to the right of the lens ?
http://i.imgur.com/H0vhAvE.jpg
Will most likely have more questions as we go .....
