Hello all,
I'm new to the IP Camera game. I'm just looking to install a small setup at home with 1x cam and 1x NVR. Having never installed CCTV before, what extras might I need but not be aware of?
I'm buying:
I know I'll need:
I'm buying:
- 1x IP Cam
- 1x NVR
- 1x Wall bracket for the Cam
I know I'll need:
- Ethernet cabling - Can this be safely routed on the underside of a soffit along the back of the house? What distance can Power Over Ethernet be used over ethernet cable?
- Does the ethernet cable need a special type of adapter to fit in the IP Cam (A Dahua IPC-HDW4231EM-AS) or does it take a regular ethernet plug?
- I'll need a hard drive but I'm sorted on that front (Getting WD Purple). Is it difficult to install the hard drive and does it need a lot of configuring?
