Hi All,
New here, found this forum via Amazon research and discussions. I'm sure this forum will be extremely helpful.
My situation? I'm an analog holdout. I've gone through several DVR's in the past 15+ years and managed to stay current.
Well, I've hit a brick wall now. Time to literally start over which is what I have planned out to do.
I want to commence with an NVR POE system and add to it , and phase out the analog for good. I've had mediocre success with my "mailbox cam" in identifying suspicious activity. My mailbox has been hit twice with vehicles and I have been paid twice thanks to the cam. I have it connected with cat5/A2D transformers as it is about a 120' run.
What I'm thinking about:
NVR 5232-16P-4KS2E to power up to 16 cams, expand 16 more with a POE sw
5241E-Z12E dedicated to LPR only. I have a fence around my property, I can get within 15' of the roadway and capture a good angle without much notice it's there.
And systematically, just start running cat5 / POE cameras around to replace what I have existing, over a short time.
Any advice for this starting point?
It would be great if anyone can recommend a POE camera that I can replace in my mailbox post; it cannot be any deeper than about 3.5". To get the analog camera to fit, I take the swivel base off. This is the second one I've gone through.
I made my mailbox by welding up 4x4 steel post, and running the cat5 inside, and out underground in conduit (pix below) And, cut a 3" hole in the .25" steel. I will abandon my mailbox cam if there isn't a suitable POE replacement.
Thanks all !
Thanks all !
