a good choice going with dahua, stick with a solid recommended vendor.
If you use Andy delivery should be less than 1 week.
On a NVR check and calculate the decoding capacity, the Bit rate that it can process. NVRs now seem to run out of processing before they run out of ports.
Read Study Plan before spending money.
My standard welcome to the forum message.
Please read the
IP Cam Talk Cliff Notes and other items in the
IP Cam Talk Wiki. (read on a real computer, not a phone). The
wiki is in the blue bar at the top of the page.
Read
How to Secure Your Network (Don't Get Hacked!) in the wiki also.
Quick start
1) If you do not have a wired monitored alarm system, get that first
2)
Use Dahua starlight cameras or Hikvision darkfighter cameras if you need good low light cameras.
3) use a VPN to access home network (openVPN)
4) Do not use wifi cameras.
5) Do not use cloud storage
6) Do Not use uPNP, P2P, QR, do not open ports,
7) More megapixel is not necessarily better.
8)
Avoid chinese hacked cameras (most ebay, amazon, aliexpress cameras(not all, but most))
9) Do not use reolink, ring, nest, Arlo cameras (they are junk), no cloud cameras
10) If possible use a turret camera , bullet collect spiders, dome collect dirt and reflect light (IR)
11) Use only solid copper, AWG 23 or 24 ethernet wire. , no CCA (Copper Clad Aluminum)
12) use a test mount to verify the camera mount location.
My test rig: rev.2
13) (Looney2ns)If you want to be able to ID faces, don't mount cams higher than 8ft. You want to know who did it, not just what happened.
14) Use a router that has openVPN built in (Most ASUS, Some NetGear....)
15) camera placement use the calculator...
IPVM Camera Calculator V3
16) POE list
PoE Switch Suggestion List
Cameras to look at
IPC-T5442TM-AS-LED
Review IPC-T5442TM-AS-LED (Full Color, Starlight+) - 4MP starlight
IPC-T5442TM-AS
Review-OEM 4mp AI Cam IPC-T5442TM-AS Starlight+ - 4MP starlight+
IPC-T2347G-LU
Review of the Hikvision OEM model IPC-T2347G-LU 'ColorVu' IP CCTV camera. (DS-2CD2347G1-LU)
IPC-HDW2231R-ZS
Review-Dahua IPC-HDW2231RP-ZS Starlight Camera-Varifocal
IPC-HDW2231T-ZS-S2
Review-OEM IPC-T2231T-ZS 2mp Varifocal Starlight Camera
IPC-HDW5231R-ZE
Review-Dahua Starlight IPC-HDW5231R-ZE 800 meter capable ePOE
IPC-HFW4239T-ASE
IPC-HFW4239T-ASE
IPCT-HDW5431RE-I
Review - IP Cam Talk 4 MP IR Fixed Turret Network Camera
DS-2CD2325FWD-I
N22AL12
New Dahua N22AL12 Budget Cam w/Starlight -- low cost entry
Other dahua 4MP starlight
Dahua 4MP Starlight Lineup
My preferred indoor cameras
DS-2CD2442FWD-IW
IPC-K35A
Review-Dahua IPC-K35A 3mp Cube Camera
If interested in
Blue Iris and other setup items see the following post
This is an intermediate / newbie guide for people just starting out looking for a surveillance setup. I know this setup might not be for everyone and there are many options. You can find a lot of this information in the Wiki: IP Cam Talk Wiki | IP Cam Talk A great place to start in the Wiki...
ipcamtalk.com
Camera Sensor size info
Sensor Size Chart Generally bigger is better
Before asking a question search the forum first...
The best way to search the forum is to use Google Advance search
set site or domain to ipcamtalk.com
Read,study,plan before spending money ..... plan plan plan
Test do not guess
if you are interested in International Dahua cameras, a forum member sells dahua (and some Hikvision) and ships world wide. You can read some of the members recommendations on his service. He also provides cameras to other forum member for evaluation and reviews.
you can email him for a quote, or purchase from his Aliexpress store or his Amazon store. The cameras are fully upgradable, he posts upgarde software when available.
Andy
@EMPIRETECANDY
[email protected]
Andy's ipcamtalk vendor forum:
EmpireTech Andy
Andy's AliExpress store:
Empire Technology Co., Ltd - Amazing prodcuts with exclusive discounts on AliExpress
Andy's Amazon store:
EmpireTech-Andy @ Amazon.com:
forum:
EmpireTech Andy
