Hello from deep south
Woady
Jan 11, 2020
2
Jackson, MS
Howdy folks. I'm Woady. I live in Jackson MS. I am wanting to learn about various camera systems and I want to install one where I live to guard my valuables. I will be asking all sort of noob questions so please be patient with me.
Cheers!
Take a look at the top of the forum, in the blue bar, at the Wiki link. Read the Cliff's Notes. You'll not regret it. It saves you a LOT of questions.
:welcome:
I work in Jackson MS a number of years ago, as a contract software engineer.
Read, Study,plan before spending money
Go slow.
My standard welcome to the forum message.
Please read the IP Cam Talk Cliff Notes and other items in the IP Cam Talk Wiki. (read on a real computer, not a phone). The wiki is in the blue bar at the top of the page.
Read How to Secure Your Network (Don't Get Hacked!) in the wiki also.
Quick start
1) If you do not have a wired monitored alarm system, get that first
2) Use Dahua starlight cameras or Hikvision darkfighter cameras if you need good low light cameras.
3) use a VPN to access home network (openVPN)
4) Do not use wifi cameras.
5) Do not use cloud storage
6) Do Not use uPNP, P2P, QR, do not open ports,
7) More megapixel is not necessarily better.
8) Avoid chinese hacked cameras (most ebay, amazon, aliexpress cameras(not all, but most))
9) Do not use reolink, ring, nest, Arlo cameras (they are junk), no cloud cameras
10) If possible use a turret camera , bullet collect spiders, dome collect dirt and reflect light (IR)
11) Use only solid copper, AWG 23 or 24 ethernet wire. , no CCA (Copper Clad Aluminum)
12) use a test mount to verify the camera mount location. My test rig: rev.2
13) (Looney2ns)If you want to be able to ID faces, don't mount cams higher than 8ft. You want to know who did it, not just what happened.
14) Use a router that has openVPN built in (Most ASUS, Some NetGear....)
15) camera placement use the calculator... 16) POE list PoE Switch Suggestion List
Cameras to look at
IPC-T5442TM-AS-LED Review IPC-T5442TM-AS-LED (Full Color, Starlight+) - 4MP starlight
IPC-T5442TM-AS Review-OEM 4mp AI Cam IPC-T5442TM-AS Starlight+ - 4MP starlight+
IPC-T2347G-LU Review of the Hikvision OEM model IPC-T2347G-LU 'ColorVu' IP CCTV camera. (DS-2CD2347G1-LU)
IPC-HDW2231R-ZS Review-Dahua IPC-HDW2231RP-ZS Starlight Camera-Varifocal
IPC-HDW2231T-ZS-S2 Review-OEM IPC-T2231T-ZS 2mp Varifocal Starlight Camera
IPC-HDW5231R-ZE Review-Dahua Starlight IPC-HDW5231R-ZE 800 meter capable ePOE
IPC-HFW4239T-ASE IPC-HFW4239T-ASE
IPCT-HDW5431RE-I Review - IP Cam Talk 4 MP IR Fixed Turret Network Camera
DS-2CD2325FWD-I
N22AL12 New Dahua N22AL12 Budget Cam w/Starlight -- low cost entry
Other dahua 4MP starlight Dahua 4MP Starlight Lineup
My preferred indoor cameras
DS-2CD2442FWD-IW
IPC-K35A Review-Dahua IPC-K35A 3mp Cube Camera
If interested in Blue Iris and other setup items see the following post
Camera Sensor size info Sensor Size Chart Generally bigger is better
Before asking a question search the forum first...
The best way to search the forum is to use Google Advance search
set site or domain to ipcamtalk.com
Read,study,plan before spending money ..... plan plan plan
Test do not guess
Hello, welcome to the forum.
Reactions: Woady
Welcome to IPCT! :)
Reactions: Woady
