Hi there. My name is Nick, and I'm from Rhode Island, USA. I've been reading posts here for some time, but now that I'm actively looking to design a PoE IP cam system for my home, I've decided to register.
I have a background in computers and networking, so my main concerns are about camera selection and placement.
My home currently has an enterprise-grade Cisco system. (I started with a Cisco lab, which then turned into a "production system." You learn a lot faster when you accidentally take down the network and you've got family screaming that Facebook or Netflix won't work!)
Anyway, for the network side of things I'm using a Cisco ASA 5520 firewall with an IPSec VPN configured. The ASA is doing the NAT-ing for my Verizon FiOS connection, eliminating the need for a separate router. The ASA is connected to a Cisco 3560 48 Port POE layer-3 switch through a dual-link Fiber EtherChannel connection. There is a second dual-link Fiber EtherChannel from the 3560 to a Cisco 4402 Wireless LAN Controller, which manages 5 Cisco 3502 access points.
I'm planning on repurposing an HP ProLiant DL380 Gen8 server for use as the NVR with Blue Iris software. 96GB RAM, 4TB storage (RAID 1, 2TB usable), redundant PSUs.
I've already created a separate VLAN for the IP cameras, and the 3560 will hand out DHCP addresses in that range, when connected to the assigned switchports.
So that's all the boring stuff. I'm looking at installing about 4 cameras, unless I'm advised to get more. I have a long, narrow lot with very little area up front, along the street. I have two parking spaces up front and a garage at the end of a ~50 foot driveway. I'd love to have one wide-angle camera at the front entry of the house, covering the front steps and sidewalk, and hopefully the two parking spaces. I'd also like a camera attached to the garage, covering the length of the driveway down to the street, as well as the rear entry door to the house. I'd also like another camera (probably mounted on the garage as well) that covers the back yard. I have a satellite photo showing the property, as well as some rough proposals of camera locations, as well as a 3D-ish version. They aren't meant to be exact and I'm not even sure if they're feasible as far as field of view goes, but it's a rough idea of what I'd like covered. Please, by all means give me suggestions!
My main concerns are keeping an eye on the two cars in the front, the front door, rear door, and the driveway. The backyard isn't really an issue but it's nice to keep an eye on.
I do have a cheap Funlux setup now I was testing and here's what I have. They're essentially the yellow and blue cameras in the diagrams. Attached are images from the driveway and back yard channels.
As far as camera selection, I'm looking at a budget of about $200-250 per camera.
I hope I haven't overstayed my welcome already, with just this one post!
Thanks,
Nick
Thanks,
Nick
