I understand you need to get this done ASAP. But from my side, you really can't give an 'expert' roadmap based on that sketch. And most here would shy away from doing so since they do not want to be bitten.
The sketch above is just that, a sketch. There is no accompanying of specific purpose. You show three arrows, which I suppose are three cams and their orientation/FOV that you are proposing? Specifically, what are you trying to achieve with these three cams? Do you want an overview that gives you a recording of the entire area? Or are you interested in the ID of people at the gate/driveway entrance? Or are you expecting to be able to ID people all along the arrow path? Those are three different jobs and there will not be one cam that can do all three at the same time. So it is important for you to define your objectives here.
I am assuming that the 100 foot shot to the street is for LPR? If so, then you will only get plates on cars going in one direction if they only have a rear plate. How high is the fence that the LPR cam has to shoot over? How wide is the road? All of this plays into the design of an LPR cam layout. Pictures would help immensely.
No mention of budget was made. Unless you state how much you expect to spend, how can anyone give you a recommendation?
