Heads up if you plan to install Windows 10 Threshold 2
Nov 4, 2015
15
I just upgraded my windows 10 box to Threshold 2. My Blue Iris runs as a service so I just assumed all was well after the upgrade. I went to launch the GUI a few days later and I was greeted with "your trial is over" screen. After I put in my key again, all was well. However, I lost 3 days of capturing video since I had not re-launched the BI application. Just a heads up to anyone planning to update to Threshold 2 soon on their BI machine.
Sounds like something to let the Blue Iris developer know about, so he can fix the problem early.
Is it a Blue Iris issue or Microsoft? Read several articles today about Microsoft removing programs or disabling programs to install the update. A lot of flack about Microsoft messing with people's settings.
Support will email you a new license key for free. This happened to me and was resolved by emailing support.
BI bug?...Microsoft bug?
Puuuleaase DO NOT tell MartyO and Fenderman about this post!
Entering my same key resolved. I contacted support and they said "Thanks, this might have changed the OS version/subversion, which is part of the key lock. Sorry for the inconvenience."
My guess it will be resolved in new versions.
I did the T2 update on my BI machine and had no issues at all, but I do NOT run it as a service. As far as update went, it was easy but annoying how it was like almost re-installing W10 again as far as settings.
