D dohat leku Getting the hang of it May 19, 2018 346 36 usa Sep 15, 2020 #1 Folks -does the 5231R have any settings to reduce false alerts from car headlights? Any exposure, settings etc that I should tinker around with? Thanks
bigredfish Known around here Sep 5, 2016 26,157 69,139 The Swamp Sep 15, 2020 #2 Backlight HLC - it will reduce headlight glare. It may not help with false alerts though. You should use IVs/Tripwire instead of plain old Motion Detection. Its an improvement. Reactions: Arjun and looney2ns
DWinters1979 Getting the hang of it Oct 3, 2017 110 24 The Netherlands Sep 16, 2020 #3 bigredfish said: Backlight HLC - it will reduce headlight glare. It may not help with false alerts though. You should use IVs/Tripwire instead of plain old Motion Detection. Its an improvement. Click to expand... IVS and tripwire isn't in the settings of this cam
looney2ns IPCT Contributor Sep 25, 2016 16,331 24,235 Evansville, In. USA Sep 16, 2020 #4 DWinters1979 said: IVS and tripwire isn't in the settings of this cam Click to expand... Turn off smart codec. Reactions: Arjun, DWinters1979, flynreelow and 1 other person
DWinters1979 Getting the hang of it Oct 3, 2017 110 24 The Netherlands Sep 17, 2020 #5 looney2ns said: Turn off smart codec. Click to expand... It's on in my setup, will turn it off. Any idea what this setting does?
DWinters1979 Getting the hang of it Oct 3, 2017 110 24 The Netherlands Sep 17, 2020 #6 DWinters1979 said: It's on in my setup, will turn it off. Any idea what this setting does? Click to expand... Great!, see the IVS setting, thanks. Reactions: looney2ns
