- Nov 24, 2017
- 131
- 217
Here's my story... I purchased a HDW5231R-ZE from Andy some time back in 2018/2019 and its been sitting in a closet since. I tried to setup the cam a couple weeks back and it showed up with a gray image on the screen. I also noticed the IR lights were lit and wouldn't go out. Everything else worked as it should - Zoom in/out, and audio. Trying to figure out what wasn't working, I disassembled the entire camera taking the lens and circuit boards apart. I noticed some sort of a triangular shaped shutter that was blocking the image after comparing it to another 5231 cam I had up. Once I figured out what was blocking the image I was able to manually move it and I went from a gray screen to a perfect image.
Does anyone know what this shutter or what this part on the lens is called? Its connected to the 4 wires you see (Yellow, Orange, Red, Brown). With the plug disconnected, I still have focus and zoom functions. Is it worth trying to fix?
