A arlobillz Young grasshopper Nov 26, 2017 80 15 Nov 28, 2018 #1 Hi Ive got an issue with the IR on above camera. Its flickering and makes the camera view very hazy. Has anyone else had similar problems ? Attachments 20181128_180812.bmp 20181128_180812.bmp 7.9 MB · Views: 42
E EMPIRETECANDY IPCT Vendor Nov 8, 2016 9,124 26,589 HONGKONG Nov 28, 2018 #2 can check if any vapor.fog inside the camera, If not the camera have to do warranty
fenderman Staff member Mar 9, 2014 36,891 21,408 Nov 28, 2018 #3 arlobillz said: Hi Ive got an issue with the IR on above camera. Its flickering and makes the camera view very hazy. Has anyone else had similar problems ? Click to expand... post an image of how the camera is mounted. It looks like something close to the camera is reflecting the IR really bad.
A arlobillz Young grasshopper Nov 26, 2017 80 15 Nov 29, 2018 #4 Ok, found out the issue at daylight. There was a cobweb which had captured a leaf which was blowing about in the wind causing the flickering. Thanks for your responses Reactions: ljw2k and fenderman
Yang n3wb Apr 17, 2018 3 2 Dec 1, 2018 #5 EMPIRETECANDY said: can check if any vapor.fog inside the camera, If not the camera have to do warranty Click to expand... Hello, I want to order IPC-SD22404T-GN, could you please tell me your wechat or mail? Reactions: JNDATHP
Yang n3wb Apr 17, 2018 3 2 Dec 1, 2018 #6 C EMPIRETECANDY said: can check if any vapor.fog inside the camera, If not the camera have to do warranty Click to expand... Could you please give me a fast reply, or your mail? I need urgently.
looney2ns IPCT Contributor Sep 25, 2016 16,335 24,242 Evansville, In. USA Dec 1, 2018 #7 Yang said: C Could you please give me a fast reply, or your mail? I need urgently. Click to expand... Look at his vender section here, all information is there.
