HDW5231R-Z - boot loop + stupid question
alekslyse
Dec 15, 2017
135
45
Ok, lets start with the boot loop. I did a firmware update of a bunch HDW5231R-Z all from same vendor, and not chinese versions. One of the cameras did not work after that, and tried to reset it - no IR lights or indicatiors, but I see it frag POE power and works in that way (not competely dead).
After the reset I got no UI, no detection, ssh, telnet or so on, BUT the ip was reset to 108 - but just for some seconds. Running ping against it I get a .108 reply 2-4 times, then quiet for 30 seconds, then 2-4 replies. Sounds like the camera is just rebooting.
Would it be a fix to be able to reupload the firmware without having to solder on any serial connections to this camera, or is it possible to halt the boot and control the camera since it does send some packets from the camera during boot?
Then to the stupid question: Those plastic packages inside the camera (with some brown stuff inside), are those for transport or permanent use inside the camera? Do you guys remove them or let them stay?
The desiccant in camera is supposed to stay there.
Search for the Easy TFTP thread (ignore the automatically generated link).
I’d also double-check that there isn’t a other device on the network also using .108
Yeah, before you resort to TFTPing the camera, check the config tool, a bonjour scanner, and your arp table for the camera's serial number or mac address.
