have they all been purples?I’ve thrown dozens of different kinds in over the years including lots of refurbished. Even giving my clients 3 years warranty I’ve only replaced 1 or 2 in 15 years.
That's great to know. ThanksIf you only have a few cameras (say a dozen or less)the wd blacks and greens are just fine. Its when you start getting up in numbers for cameras where you start to notice the lower end drives cant keep up with the sustained writes. If you have more than a dozen cameras you should really start considering multiple drives, or even a raid of some kind to spread the writes across multiple drives.
No, every kind imaginable. My only criteria has been 7200 rpm and large cachehave they all been purples?
or u have tried WD blacks or greens?
How much louder in reality are the wd blacks vs the purples?Unlimited budget and no care about noise - WD Blacks or enterprise 7200rpm
Budget and care about noise - WD Purple
Handy with tools and great value - WD External on offer and remove the drive![]()
The 7200rpm drives will be “clicky” compared to their 5600rpm brethren. I wouldn’t want my BI server with 4 Exos 24 drives in the same room with me.How much louder in reality are the wd blacks vs the purples?
annoys the heck out of me and has to be dealt with.
or similar will work well.These are ok for camera use 24/7? Price per TB is cheaper than WD purples. I may go this route to replace my failing 14tb purple.I use Seagate Exos x24 drives. Just bought another 24TB drive last week.
Exos are Enterprise. They are a step above WD Purple. On par with Purple Pro.These are ok for camera use 24/7? Price per TB is cheaper than WD purples. I may go this route to replace my failing 14tb purple.
I bought it April 2021. Its making weird noises and is not recognized about 50% of the time after cpu reboots. Another reboot and it shows up, but I fear one of these times it won't.How old is that failing purple out of interest?
Good to know.Exos are Enterprise. They are a step above WD Purple. On par with Purple Pro.
