HD Wi-Fi Endoscope - $34 one day only
zero-degrees
1,335
849
Don't know anything about it - read some reviews online and they were positive for the most part.
This tool gets discussed here from time to time. This caught my eye this morning as a one day sale. What is cool about this one is the included end attachments that are included with the adjustable LED light as well.
SwissTek Professional HD Wi-Fi Endoscope - $34.99 + $5 standard shipping
  • Resolution: 1200p, 1280x720, 640x480, 320x240
  • Camera Diameter: 8.4mm
  • Waterproof: IP68
  • WIFI Transmission Distance:15 Meters
  • Battery Capacity: 500mAh
  • Focal Distance: 3mm-8mm
  • Power Supply: DC 5V 1 x Wi-Fi
In the Box:
  • (1) Endoscope
  • (1) Micro USB to Micro USB Cable
  • (1) USB to Micro USB Cable
  • Accessories - (1) Mirror, (1) Hook, (1) Magnet
  • (1) User Manual
  • The new Professional HD Wi-Fi Endoscope features a higher 1200p resolution, improved IP68 waterproof rating, 8 way adjustable LED and 4 accessory attachments.
  • It features a 3.5 meter semi rigid cable with 8 level adjustable LED lighting, for professional and recreational applications.
  • With a built-in Wi-Fi signal, this borescope can be quickly connected with your smartphone via Wi-Fi.
  • Compatible with all Wi-Fi enabled smart devices.
  • Easy to set up and use after installing the newly designed companion APP, "HD SEE."
  • Improved Semi-Rigid Cable for improved applications. Featuring super Hi-Vision 2MP HD camera allows you to capture image or record video at a close range.
  • Photos and videos can be stored directly into you device so you can share it with your friends.
  • Semi-rigid cable which can bend and hold it's shape to access a wide variety of confined place to meet with different using needs.
  • Built-in lithium battery with working time up to 1 hour, and can be easily recharged by Android Phone or PC/Power Bank within DC 5V,1A.
  • Perfect tool for HVAC inspection, vent pipe, machine equipment, engine, automotive, boat, parts assembly, construction sites, wind turbines, aircraft inspection.
Reactions: Fastb and looney2ns
I have no immediate need for one, but damn for that price it;s a lot of cool, I'll find something to do with it :D
Reactions: zero-degrees
This kind of endoscope cameras are crap ! mainly because the wire is too flabby so you will push it 1 meter max then the wire will start to fold, there are some models with much less flabby cable, also the light power is very low, the DOF is very short, if you push such camera inside a tube with a bit of dirt it will come over the lens (as the camera's head will act like when you push a brush).
The only way I used it with some satisfaction was to record some mouse hole because I did not want to use standard sized camera but more discreet one ;-)
