- Nov 17, 2015
- 105
- 9
Hello all,
I am having trouble using the AXIS camera protocol on a Hikvision NVR (newest firmware)
I can get the axis camera to work using the ONVIF protocol, but since the camera is a fisheye, I need to capture the panoramic stream which is the second stream. If I try using stream/channel number 2 in camera configuration, it does not work.
here’s the current network setup:
AXIS Camera:
Camera User/pass: same as NVR
ONVIF user profile user/pass: same as NVR
camera IP: 10.1.1.13
Camera gateway: 10.1.1.1
NVR
10.0.1.50
PoE IP range: 10.1.1.1
NVR Camera setting (This works
Manual Add
IP: 10.1.1.13
Protocol: ONVIF
Port: 80
TCP/UDP: Auto
Channel: 1
Username: same as Axis ONVIF profile
Password: same as AXIS ONVIF profile
NVR Camera Setting (does not work)
Manual Add
IP: 10.1.1.13
Protocol: AXIS
Port: 80
TCP/UDP: Auto
Channel: 2
Username: same as Axis Camera
I need stream 2 as stream 2 is the Pano view. I cannot under any circumstance get this AXIS protocol to work. Is it not supported? Am I doing something wrong? I feel the issue is with the NVR rather than within the camera
AXIS Camera:
NVR
10.0.1.50
Manual Add
IP: 10.1.1.13
Protocol: ONVIF
Port: 80
TCP/UDP: Auto
Channel: 1
Manual Add
IP: 10.1.1.13
Protocol: AXIS
Port: 80
TCP/UDP: Auto
Channel: 2
