- Feb 5, 2017
- 4
- 0
Hello,
I am new this forum, but it looks to be the perfect community to help me solve my problem, my friend has a Hikvision DS-7204HQHI DVR NVR, it has one channel for an ip camera, so he got a cheap ip camera from ALDI called a MAGINON vision IP security Camera, he tryed to set them up but failed, so he brought them, to me, at first i taught it would probably be simple enough, but i never really had experience with cameras to be honest, i have connected into though its web interface after i connected it to my home network, and i then changed it ip to a static ip address(192.168.1.111), i then set up the hikvision and also gave that a static ip(192.168.1.110), i then went to configuration and added an ip camera, i manually filled in the info and pressed okay but it said network is unreachable, so i double checked there subnets and default gateways and ports, but i what i speculate the problem is to do with the protocol or maybe a firewall issue, but i have very little experience with cameras, and im not sure what to dow with the protocals on the hikvision, it only give two options, Hikvision and ONVIF
