Hi,
On the advice of you guys, I purchased a Hikvision DS-7604-E1/4P NVR and also a Hikvision DS-2CD2332-I cam thinking these would work seamlessly together, but I've battled to get these working and getting nowhere....
Firstly I have the Camera Hardwired to the Router on the 192.168.1 network via an POE injector.
Secondly I have the NVR Hardwired also to the Router on the same 192.168.1
I have spent days trying to get the NVR to find/add the Camera but it simply cannot locate it, even when the cam and nvr are on the same Network....
In frustration I reset the Camera to default and attached it to back of the NVR which works instantly and assigns its own 192.168.254.x address...
So yes the camera works via the NVR, but the problem is I use the IPCam viewer app on the iphone to view the camera and the picture is not anywhere as good as the picture I was getting when I went direct to the camera....
I presume this is because the NVR has about 30% of the settings that the Camera has. But because the damn camera is on the 254 NVR network, I can't access to change any settings...
I set the NVR to the same settings as I had on the camera itself, but picture quality isn't anywhere as good and like I said, half the options are missing in the NVR compared to the camera.
Why can't the bloody NVR allow me to add the Camera via the 192.168.1 Network? That way at least I could access the camera directly and tweak all the settings which made it perfect???
Surely there must be a way to add camera to this NVR which are on the network and not plugged into the rear of it?
Please help, this is doing my head in.
All I want to do is retain the camera on its current IP address on the 192.168.1 network (so that I can access it via iphone app and have the best settings) and then also have a NVR which records the stream from the camera. I bought both Hikvisions items thinking I wouldn't have any issues, but man its been anything but....
