So I have a NUC setup with the following
I have 6 x Hikvision Cameras and 1 x D-Link Baby Camera.. It's been running for a year or more.. Even forgotten what the cameras are recording at.. showing bitrate of approx 500 kB/s and 15 fps for all Hikvision Cameras and 130 kB/s and 30 fps for D-Link Camera
Current recording setup gives me about 2 weeks of 24/7 recording history which is more than enough I guess.
CPU usage is constant 94-98% all the time with BlueIris using approx 88-94% CPU and 3.1GB Memory without the app open. So the NUC is pretty much taxed 24x7
Is the setup ok or should I upgrade something or reduce some settings to make it better? If I do sometime want to use the NUC / update it or use another software. I sometimes stop BlueIris so that CPU usage drops and can use other applications.. But I don't do this everyday.
Hope NUC doesn't blow up on me some day lol..
If I keep the "Export Settings" from Options Config in Dropbox will that save everything including camera config and properties as well and restore.. Or should I save that + goto each camera and do export for each camera individually as well via their properties? Just looking for DR scenario
- i5-4250U CPU @ 1.30 Ghz
- 8GB RAM
- 4TB WD Elements connected via USB for recording
- 256GB SSD for OS and Blue Iris Configuration to sit on.
- Windows 10
