- Jul 16, 2016
- 263
- 60
Hi All,
I would like to post the question to all forum members.
Hoping someone can really give some advice in building
a low power system running BI at 24/7.
I have built surveillance system in the past with cheaper
micro atx motherboard for office usage, but somehow
it wouldn't last after about 2-3 years.
I am not sure, whether I should go for large ATX
motherboard (more durable), for better investment,
instead of opting for cheaper micro ATX motherboard.
However, I prefer a small factor since it is going to be
used at home, not office.
So I am more inclined to
use micro ATX or mini ATX motherboards available the market.
That is why I looking at the Gigabyte motherboard shown below.
I am thinking about using the following components.........
Motherboard = Gigabyte H97N-WIFI LGA 1150
Link: http://www.gigabyte.com/products/product-page.aspx?pid=4992#ov
Would this motherboard be a good choice for home use?
CPU = i7 4790s LGA 1150 low power (@TDP= 65w)
Link: http://ark.intel.com/products/80808/Intel-Core-i7-4790S-Processor-8M-Cache-up-to-4_00-GHz
What I am worrying about is the motherboard's H97N chipset,
As you add more and more ip cameras, the chipset will have
work harder to cope with handling large data, transferring to
the hard disk. Not sure how much bandwidth is available?
Yet another problem that I worry is the heat
generated by the chipset. I would think it will be sizzling hot,
although case fan can alleviate some heat from the motherboard.
The system will be placed at the attic, which is hot all year round
since I based at a tropical sunny country. So having case fan is
a must for my application.
Any advice is given is most appreciated.
Thank you.
Thank you.
