@fenderman got a question for you. I just dug up my old gaming box that I'm thinking of converting to BI4 station.
Its couple of years old. Want to see if its up to par to run BI4 with hardware accelaration or should I be looking at something newer?
Motherboard: Z77 Extreme 4
http://www.asrock.com/mb/Intel/Z77 Extreme4/
32GB 1866 RAM ( can remove non needed dimms)
CPU: Intel i7-3770s
http://ark.intel.com/products/65524/Intel-Core-i7-3770S-Processor-8M-Cache-up-to-3_90-GHz
250GB SSD drive for windows 10
Intel HD 4000 graphics
3tb WD red HDD or I can get purple if needed.
Are these still good to use or should i get one of the refurb dells that you recommend? will they give me better performance?
thanks
Alex
CPU: Intel i7-3770s
thanks
Alex
