I searched and didn't find much on this, other than troubleshooting I've already tried. When enabling hardware decoding, several of my cams show bands of corruption across the top:
System:
Troubleshooting so far:
Anything else I can try? CPU w/out decoding is ~34% (with console open), so not critical to get it working, but if it's worth it, I'd like to take advantage of the feature.
System:
- BI v4.3.9.7 x64
- W10 Home
- i5-6400 w/ Intel HD530 integrated graphics
- Cams: Amcrest IP3M-954E / Dahua IPC-HFW4421SP / Dahua IPC-HFW1320SP
- Intel graphics updated to latest drivers (corruption occurred before upgrade as well)
- All cams at latest firmware (with corruption happening prior upgrade)
- Switched all cams from H.264H to H.264 (read this in a previous thread as a possible fix...unfortunately not)
- Tried HD (no VPP) and HD+VPP...same issue
- Tried running BI as a service and not as service...same issue
- Verified that the resolution BI shows for each cam matches what the cam is configured to...another thread mentioned a mismatch causing extra lines of blank pixels...
