I'm trying to find a solution to use 19 older cameras, 13 of which are ACTi ACM-4200 1.3MP 5fps, 4 are IQeye511 1.3MP 5fps, a Hikvision and a noname dome camera both also about 5fps and 1.9MP.
It all use to run on a server with old software, that I believe milestone bought, Intel Q9300 quadcore and 2GB ram, but the system drive died and I don't have license keys or install files for the software anyway. But it use to run fine on that.
I installed Windows7 and BlueIris(licensed) on a new SSD on this Q9300 quadcore and upped it to 6GB ram
My problem is that the Hikvision and the 13 ACTi cameras always run fine, but the 4 IQeye511 and the noname dome, often drop to 0.7fps or simply stop doing any fps
If I disconnect the 13 ACTi cameras, the IQeye551 cameras then seem to work a lot better on their own.
I can only really assume then, that this is due to the server being too old and slow for BlueIris, or that the method (jpeg refresh) BlueIris talks to the IQeye511 cameras with, needs a lot more power to run, than the ACTi cameras do.
So I've been looking at a Dell T20 as a replacement server, since the Intel E3-1225 has hardware acceleration.
But does hardware acceleration help with non h.264 cameras, would hardware acceleration help with these types of cameras?
