If I turn on Intel, Intel+VPP, or Intel Beta my cpu (I7-11700 non K) usage goes up by about 10-15%, Intel gpu goes from 0 up to 25%, and temp goes from 45 up to 58 degrees C. I don't worry about the cpu usage, since I'm only up to 20 or 30, or those temps, but the sound of the fan bothers me, since this is on my desktop (and I have a very good and quiet cpu cooler: MA620M, in a quiet case: define 7).
Does this make any sense? If so, what do I get out of it for the extra heat and noise? Snappier GUI experience?
This is with a hikvision 2132, a 2142, and 2x PCI-T18F2S.
Thanks for any insights.
Eric
Eric
