Hard Drive recommendations?
Just bought Hikvision NVR (DS-7716NI-SP/16)
For Home use 16 cams and probably just have cameras recording with motion.
Hard drive prices have come down quite a bit so looking at 3TB ... believe that should be more than enough for my needs? 4TB not much more ... so suggestions there also if better choice?
What drives are recommended for NVR? Use same criteria to evaluate drives as you would if buying for a desktop computer?
Thanks, Patrick
Thanks, Patrick
