Hi all, first post here
I'm in the middle setting up my system to access BlueIris (v5.3.6.1) from the outside, my current setup is as follow:
wan -->> pfSense with HAproxy (SSL offload) and Let's Encrypt --->>BlueIris
BlueIris is set up to require authentication for connection NON-LAN connections , but a soon as put my URL on my phone(with no Wi-Fi) it bypasses authentication straight to the cameras
question:
since initial connection is done from WAN to pfSense HAProxy(encrypted), and then forwards it to BlueIris(unencrypted) , does it thinks that is coming from LAN?
if I enable Authentication from "all connections" it works just I expected , but since I'm using the local AI Tool that uses an URL trigger, I will get issues when I enable the Authentication from "all connections"
Is there a setting that I'm missing or something?
Thanks!
question:
Thanks!
