So I have have my first confirmed death of a Hik due to water. I have disassembled it to try and see where the weak point was at and the best I can figure it came in around the reset switch on the back. The neat part is that is is still wet in there, and the camera has been sitting waiting for me to take it apart for almost a month! Once it got in it was not getting back out!
I was planning to take this one apart and use the cable for another one that has damaged pins out of the box but the cable is not going anywhere as it is sealed to the casing with some type of sealant that was poured around the cable sealing it very well. My vendor said it was installation damage, but it was not. Not much I can do to argue though. The camera did power back up after being off for a month, but it was stuck in night mode, and some spots on the sensor appear to be bad. Could be water in there though too as it was truly fogged in there.
Anyway, I have now had three total Hikvision issues. Water damage to one. One got a stuck IR filter inside of a week of being installed. One with pin damage to the cable fresh out of the box. Not bad at all really with the amount I use, I've lost count but it has to be 200 at this point. I just ordered 42 more yesterday actually (from a new vendor too)
I may have a couple coming back dead due to a lightning strike but I've not got them back to test yet. Still, when my ACTi cameras took a hit they ALL died and so far the Hiks are much more robust.
