Last night I had a power failure and failed my GPU. I'm using an old gaming rig and there is no built in graphics on the motherboard. I'm running an I7 9700KF on an MSI mobo with 16 gb or ram. The gpu was a RTX 2080 TI. My cpu usage is usually 20-30% and hasn't changed much until it starts processing an image then it jumps up into the 60-70 range. If my motherboard had integrated graphics I probably wouldn't even replace it but I'm getting boot errors sometimes and the the GPU fans will go to 100% for no reason sometimes. Any recommendations? It's an old system so I don't want to slam a ton of money into it.
