- Aug 2, 2016
- 6
- 0
I have been reading up on i-frames, been experimenting with the settings on a camera that I am not recording to see what works.
My question (although basic, I thought I knew the answer) is do I set the same settings on the NVR when recording?
Also do I have to use an i-frames length that fits (as a whole number) to the frame rate, i.e 15fps using i-frames of either 3, 5 or 15 and not 4, 6 or 12 if you see what I mean.
Thank-you
Sent from my D6503 using Tapatalk
Thank-you
