Hi,
I been super happy with all my hikvision cameras, all have worked perfect as stand alone, with blue iris and with mobile apps.
Recently i had an issue with Google Chrome not displaying the cameras, asking for an extra pluggin, searching the web, i was not alone, and seem Chrome change something between v40 and v42, and place a plug that was needed to display from on to off, this was simply fixed by entering the setting of chrome and enabling it. But this was a temporary fix, as it seems the plugin support will be dropped, some say September, but chrome starting to display "This site uses a plugin (Web Components) that will soon be unsupported".
While my real surveillance is done with Blue Iris, and all my mobile apps work great with the cams, i still find very useful to be on my PC and check on the outside, like someone rings the door, or to check i closed a door, so on... so i come to you guys to see what options do i have? or what are you guys planning? Anyone know if hikvision has another alternative, like new firmware that will use a supported pluggin?
Thanks for any info, suggestions or advise.
