Good cam
4MP on a 1/3: sensor won't do very well at night. The 2231 or 3241 are better choices even though they are 2MP. Unfortunately they're also more expensive but do have the proper sensor/resolution ratio.
Quick guide -
The smaller the lux number the better the low light performance. 0.002 is better than 0.02
The smaller the "F" of the lens the better the low light performance. F1.4 is better than F1.8
The larger the sensor the better the low light performance. 1/1.8" is better (bigger) than 1/2.7"
The higher the megapixels for the same size sensor the worse the low light performance. A 4MP camera with a 1/1.8" sensor will perform better than a 8MP camera with that same 1/1.8" sensor.
Disclaimer - These sizes are what the manufacturers advertise and may, or may not, be the true size of the sensor in the camera.
720P - 1/3" = .333"
2MP - 1/2.8" = .357" (think a .38 caliber bullet)
4MP - 1/1.8" = .555" (bigger than a .50 caliber bullet or ball)
8MP - 1/1.2" = .833" (bigger than a 20mm chain gun round)
2231 Review
Review-OEM IPC-T2231RP-ZS 2mp Varifocal Turret Starlight Camera
3241T-ZAS Review
