Good Blue Iris Machine
Not bad. You can get i7-4790 systems for a similar price, and they should perform better, but they are also older, not likely to come with as much RAM or disk space.
I got a similar deal on ebay a while back but with 8gb ram.. I'm more than happy with mine.. i finally installed a crucial mx500 250gb ssd yesterday too. Boots in seconds compared to mins
That is a very good deal. I’ve got the same 600 G2 but mine only had 4gb of ram. It can accommodate a SSD and 2 full size hard disks and is also fairly quiet.
Reactions: Cameraguy
That's a great deal!
I 've got an old i7-3770k that has run 24/7 since 2012.
It's been rock solid and abused daily for years. It still stacks up well against the i5-6500
comparison i7-3770k vs i5-6500
But, looking @ doing a i9-9900k build before end of year. But prices for all great components are stupid expensive.
I guess weighing that up against buying and building possibly another 2 machines over another 7 years, I'm slowly talking myself into it.
I would have pounced on the deal if it were still available; for a 16 GB i5-6500 that was terrific. I have a similar (but 8 GB) system but for that price I could have another system to mess with. :-)
Just to give an idea of how cheap I'm seeing thing in the area:
HP Workstation 8300 i7 3.4ghz proc. 4GB ram, 128 GB SSD, comes with a DVD burner No monitor, keyboard or mouse.
Fwiw, I'm using similar for a media server and its fine. Personally for this one I'd bump it to 8gb ram but I think for under $100 you could have a decent BI system.
Link?
No Intel Quick sync in third generation. I would spend a bit more for at least fourth generation.
Sent from my ONEPLUS A6013 using Tapatalk
I had asked about it and considered it. Asked the guy to tell me what proc it is and he just said the ghz speed. By that point I had slowed down and decided I didn't NEED it so I didn't ask more. Not bad as the guy said there was only 1 dimm installed so to bump up the ram, you wouldnt have to remove any.
This is a good machine will last through a lot of high MP/s cams:
HP EliteDesk 800 G4 SFF i5-8500 3.00GHz 8GB NO HDD Warranty 2021 | eBay
The price is right at only $430 shipped. Buy a NVMe for OS and you are good to go.
https://www.amazon.com/dp/B07KGLN3HN/ref=twister_B07QJ7ZFQ3
0-500 MP/s ----- 3rd-7th gen i5 desktop CPU (4 cores)
500-800 MP/s --- 3rd-7th gen i7 desktop CPU (4 cores + hyperthreading) or 8th-9th gen i5 desktop CPU (6 cores)
800-1100 MP/s -- i7-8700 (6 cores + hyperthreading) or i7-9700 (8 cores) or the K edition of either
1100-1500 MP/s - i9-9900K
1500+ MP/s ----- Then it varies. Pick something near the top of this chart, or consider a different VMS than Blue Iris.
Quick sync guide:
Getting Intel Quick Sync to work with Blue Iris (Settings & Troubleshooting)
Quick Sync started with 2nd gen, where it is limited to 1920x1080 max res. 3rd gen has better Quick Sync decoding with no resolution limit that I know of.
I could be wrong then. I thought BI support for quicksync started with 4th gen, but I'm wrong about lots of things.
