Hey folks, just a general question on Ethernet switches.
I've run a total of 32 cameras both internally and externally at my house. Up to now, I've made sure that when I extend my network runs (particularly outdoors), that I use Gigabit POE+ switches. I will typically install them mounted inside waterproof enclosures and have had years of trouble-free service.
The only issue is the size of these things. Believe me when I say that I've shopped around, and purchased quite a number of these so it's not without looking. However, if you drop down to 100Mbps, there are numerous and quite small (we are talking 3x4 inches in some cases) switches to be had! Of course, the power brick that goes along with them can be big, but that's a separate issue.
So the real question is....would I be better off sticking to the gigabit switches, or is it overkill if all I am doing is connected cameras to them? Again, these switches are dedicated solely to providing power and Ethernet connectivity.
Any thoughts or insights would be greatly appreciated!
